gigabit switch chip
Aug 23, 2004 4 Replies
Jump to replies (4)
I'm looking for gigE switch chip to embed on a board we design. requirements are 4 X gigE ports and 2 X FE ports. switch should be managed.
Can someone recommend/point such chips (cant find too many...)
TIA,
wd.
thanks,
those 2 are the only ones I found.
do you know of any alternatives?
thanks!
wd.
You can always try Intel.
There are many others.
Regards, Allan
