Ethernet Transmitter Interrupts
Jan 05, 2005 1 Replies
I am having a problem with my server booting all the clients off of the database software citing that contact was lost with the user. I've been trying to figure the problem out and have winnowed it down to the router or the cable from the router to the server (I doubt it is either of these, because I don't get any collisions etc.) So, out of curiousity I figured I'd run an Ethernet Diagnostic Report and found that there were 739,064 Interrupts on the port in use. Could this be my problem?? Any insight would be appreciated.
thanks.
In article , M Landman wrote: :I am having a problem with my server booting all the clients off of the :database software citing that contact was lost with the user. I've :been trying to figure the problem out and have winnowed it down to the :router or the cable from the router to the server (I doubt it is either :of these, because I don't get any collisions etc.) So, out of :curiousity I figured I'd run an Ethernet Diagnostic Report and found :that there were 739,064 Interrupts on the port in use. Could this be :my problem?? Any insight would be appreciated.
It would depend on the NIC and the driver, but it wouldn't be uncommon for a NIC to DMA packet contents into an operating system buffer and then to interrupt the OS to signal that the packet was there. In other words, in common implimentations, an interrupt is normal and a Good Thing [you don't want the CPU to have to poll the NIC and do the copy-in as the bytes are ready.]
