Ethernet Line fault detection
Nov 14, 2004 2 Replies
Hi Guys and Gals,
I am faced with a requirement to be able to hardware detect line faults (ground faults and shorts) on an ethernet link. Since this line is behind a balanced isolation transformer (and I new to the ethernet game) I am uncertain if this can even be done. Does anyone have any experience with this situation? It has to be done real time (could be coordinated to ensure no data traffic if necessary).
Thanks for any inputs in advance..
Frodo
Bonsoir Frodo,
If an Ethernet port doesn't receive the link test pulses (those existing between data frames) during 50 up to 150 ms, due to any failure in the link segment, it results at least 2 events:
- the transmission is deactivated,
- the associated green LED (often called Link), if it exists, becomes off.
For me, there is no relationship with the balanced isolation transformer. Michelot
(snip)
Shorting of one wire of a pair to ground likely wouldn't stop link pulses, and maybe not ethernet. It might greatly increase RFI emission, though.
I did once have a short in a coaxial ethernet system, which is silent, unlike an open which is detected quickly.
-- glen
