Which vlan does it belong to? - CatOS 4006.
Jul 06, 2006 2 Replies
Walter Roberson
It has to do with it not being connected. However, my CatOS is too rusty to recall whether VTP plays a factor in this.
Seeing the output below where do you think the port 6/47 has gone?
VLAN Name Status IfIndex Mod/Ports, Vlans
1 default active 6 1/1-2 2/1-48 3/31-48 4/1-48 6/1-42
10 VLAN10 active 107 3/9-12
20 VLAN20 active 157 3/1-8
30 VLAN30 active 158 3/13-16
40 VLAN40 active 208 3/17-22
50 VLAN50 active 211 3/23-30
60 VLAN60 active 207 6/43-46,6/48
1002 fddi-default active 7
1003 token-ring-default active 10
1004 fddinet-default active 8
1005 trnet-default active 9
The answer is VLAN 60 has shown below:
Port Name Status Vlan Level Duplex Speed Type
----- ------------------ ---------- ---------- ------ ------ ----- ------------ 6/47 notconnect 60 normal auto auto 10/100/1000
But why the sh vlan command reports it doesn't belong to any VLAN?
Alex.
I forced the port to belong to the VLAN 60 again but still no effects. Could it be broken? How to check it out?
switch> (enable) set vlan 60 6/47 VLAN Mod/Ports
60 6/43-46,6/48 switch-ts-00> (enable) sh vlan VLAN Name Status IfIndex Mod/Ports, Vlans
Many thanks,
Alex.
