Which cable(s)? Madge AccessSwitch 20 and Cisco router
Nov 14, 2008 2 Replies
Doug McIntyre
Sounds like quite a chase from googling it. The 44-pin connectors are totally custom and unique to that box. Looks like Tandberg made some at one point for one Madge box... 15 pin may be be for your T1/PRI. They had Tx on pins 1 & 9 and RX on pins 3 & 11 if its stock 15pin T1…
Picked up a Madge/Initia AccessSwitch 20 off eBay with 8 BRI, 1 PRI, 1 E3, and 2x 44 pin connectors and 2x 15 pin connectors.
I have been told that the two 44 pin and the two 15 pin connectors can be used for frame relay. Only problem is, I have no clue which cables to purchase to get it hooked into my lab...
Here is what is printed on the back:
(---44 pin connector---) (---44 pin connector---) A1 - RS449 / V.35 / x.21 - A2
and to the right of those ports is:
(---15 pin connector---) (---15 pin connector---) A1 - RS366A/RS366 - A2
Sam
The 15 pin may be be for your T1/PRI. They had Tx on pins 1 & 9 and RX on pins 3 & 11 if its stock 15pin T1 pinout.
You may have to break down at get them from Initia themselves.. (hopefully you got the programming software too).
Hmm, seems like I should just go from the 44 pin (male) to V.35 (male) to V.35 (female) to DB60.
Found this:
