vpn traffic slower than expected
Dec 12, 2006 10 Replies
Jump to replies (10)
I set up a site to site vpn tunnel between a 2621x router and an ASA
5510 (T3 line for router and E1 for ASA). Speeds are expected to be slower but what I am seeing is very very very slow speeds. This happens with anything from downloading (large and small) files across the tunnel, citrix connections across the tunnel, remote desktop controlling a machine across the tunnel, etc. Pings across the tunnel result in these times:
bytes=32 time=206ms TTL=127 bytes=32 time=177ms TTL=127 bytes=32 time=202ms TTL=127 bytes=32 time=229ms TTL=127
Both endpoints are outside interfaces that all internet traffic also passes through from the respective sites. The MTU setting on the router is 4470 and the ASA is the default 1500. I'm not sure if that should have an effect on anything. I also disabled pre-fragmentation and no luck.
Anythign else I can look for and can do to get this to improve?
Thanks.
I did some testing with back2back 2621's a while back using the ethernet as the "WAN". IIRC I couldn't get over half a meg at best, the router is not built for encryption. There is, however, a slot to put an encryption card int there that will bring you up to a reasonable speed. Might need a memory upgrade tho...
Watch the CPU when you do an xfer, the encryption process is probably going through the roof.
-Wil
psychogenic wrote:
Thanks Wil. That's bad news. However I'm not even getting half a meg. It's more like it peaks at 200k.
The testing I spoke of was several years ago so I am rather fuzzy on the details but I would expect about the same performance that you are seeing. Look at the CPU, it will tell you the story.
show proc cpu
-Wil
psychogenic wrote:
Wil Schultz wrote:
This is what I get. Unfortunately this loosk Greek to me. :) Its hovering around 29-39%. What would constitute something should be looked at? I scrolled through the various processes and the highest % i see are 1.5 or so.
internetrouter#show proc cpu CPU utilization for five seconds: 29%/27%; one minute: 30%; five minutes: 28% PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 1 20 31 645 0.00% 0.00% 0.00% 0 Chunk Manager 2 11459460 2361288 4853 0.08% 0.10% 0.10% 0 Load Meter 3 140 3609 38 0.00% 0.00% 0.00% 0 TACACS+ 4 0 1 0 0.00% 0.00% 0.00% 0 EDDRI_MAIN 5 35193124 2099949 16759 0.00% 0.32% 0.30% 0 Check heaps 6 94572 36659 2579 0.00% 0.00% 0.00% 0 Pool Manager 7 0 2 0 0.00% 0.00% 0.00% 0 Timers 8 136488 215722 632 0.00% 0.00% 0.00% 0 ARP Input 9 0 2 0 0.00% 0.00% 0.00% 0 ATM Idle Timer 10 12 15953 0 0.00% 0.00% 0.00% 0 AAA high-capacit 11 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT 12 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager 13 0 4 0 0.00% 0.00% 0.00% 0 DDR Timers 14 4 3 1333 0.00% 0.00% 0.00% 0 Entity MIB API 15 450820 348448 1293 0.00% 0.40% 0.33% 0 EEM ED Syslog 16 626216 2600273 240 0.00% 0.00% 0.00% 0 HC Counter Timer 17 0 14 0 0.00% 0.00% 0.00% 0 Serial Backgroun 18 0 1 0 0.00% 0.00% 0.00% 0 RO Notify Timers 19 0 1 0 0.00% 0.00% 0.00% 0 Crash writer 20 3416 393978 8 0.00% 0.00% 0.00% 0 Environmental mo 21 230680 11805789 19 0.00% 0.00% 0.00% 0 GraphIt 22 0 2 0 0.00% 0.00% 0.00% 0 Dialer event PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 23 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect 24 0 2 0 0.00% 0.00% 0.00% 0 XML Proxy Client 25 0 2 0 0.00% 0.00% 0.00% 0 SMART 26 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd 27 111388 2983706 37 0.00% 0.00% 0.00% 0 Net Background 28 313936 129732 2419 0.00% 0.22% 0.18% 0 Logger 29 357716 11805792 30 0.00% 0.00% 0.00% 0 TTY Background 30 3623704 11806028 306 0.08% 0.04% 0.01% 0 Per-Second Jobs 31 256 98509 2 0.00% 0.00% 0.00% 0 DHCPD Timer 32 0 1 0 0.00% 0.00% 0.00% 0 AggMgr Process 33 0 1 0 0.00% 0.00% 0.00% 0 dev_device_inser 34 0 1 0 0.00% 0.00% 0.00% 0 dev_device_remov 35 11516 1969171 5 0.00% 0.00% 0.00% 0 mxt5100 36 0 1 0 0.00% 0.00% 0.00% 0 sal_dpc_process 37 0 1 0 0.00% 0.00% 0.00% 0 ARL Table Manage 38 0 2 0 0.00% 0.00% 0.00% 0 ESWILPPM 39 0 2 0 0.00% 0.00% 0.00% 0 Eswilp Storm Con 40 0 2 0 0.00% 0.00% 0.00% 0 SM Monitor 41 0 2 0 0.00% 0.00% 0.00% 0 VNM DSPRM MAIN 42 0 1 0 0.00% 0.00% 0.00% 0 DSPFARM DSP READ 43 0 2 0 0.00% 0.00% 0.00% 0 FLEX DNLD MAIN 44 0 2 0 0.00% 0.00% 0.00% 0 NM-1VSAT-GILAT M 45 0 1 0 0.00% 0.00% 0.00% 0 HDV background PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 46 0 2 0 0.00% 0.00% 0.00% 0 Multi-ISA Event 47 0 1 0 0.00% 0.00% 0.00% 0 Multi-ISA Cleanu 48 3372 393978 8 0.00% 0.00% 0.00% 0 Call Management 49 0 2 0 0.00% 0.00% 0.00% 0 Net Input 50 4477396 2361299 1896 0.08% 0.06% 0.06% 0 Compute load avg 51 14942036 199288 74977 0.00% 0.17% 0.12% 0 Per-minute Jobs 52 0 1 0 0.00% 0.00% 0.00% 0 AAL2CPS TIMER_CU 53 0 1 0 0.00% 0.00% 0.00% 0 IGMP Snooping Pr 54 0 1 0 0.00% 0.00% 0.00% 0 IGMP Snooping Re 55 57656 429342 134 0.00% 0.00% 0.00% 0 CRYPTO IKMP IPC 57 221100 11805811 18 0.00% 0.00% 0.00% 0 Crypto Device Up 58 294948 11805806 24 0.00% 0.00% 0.00% 0 Kontrol Common H 59 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R 60 1756 9281 189 0.00% 0.00% 0.00% 0 AAA Server 61 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc 62 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr 63 0 1 0 0.00% 0.00% 0.00% 0 AC Mgr 64 264984 1203944 220 0.00% 0.00% 0.00% 0 CDP Protocol 65 12756540 9476699 1346 1.14% 0.25% 0.12% 0 IP Input 66 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl 67 88 19662 4 0.00% 0.00% 0.00% 0 MOP Protocols 68 0 5 0 0.00% 0.00% 0.00% 0 PPP Hooks 69 220 53 4150 0.32% 0.05% 0.01% 66 Virtual Exec PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 70 0 1 0 0.00% 0.00% 0.00% 0 SSS Manager 71 11720 1575727 7 0.00% 0.00% 0.00% 0 SSS Test Client 72 0 1 0 0.00% 0.00% 0.00% 0 SSS Feature Mana 73 88368 46174890 1 0.00% 0.00% 0.00% 0 SSS Feature Time 74 0 1 0 0.00% 0.00% 0.00% 0 VPDN call manage 75 0 1 0 0.00% 0.00% 0.00% 0 L2X Socket proce 76 0 1 0 0.00% 0.00% 0.00% 0 L2X SSS manager 77 0 2 0 0.00% 0.00% 0.00% 0 L2TP mgmt daemon 78 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana 79 0 2 0 0.00% 0.00% 0.00% 0 KRB5 AAA 80 0 1 0 0.00% 0.00% 0.00% 0 IPv6 RIB Redistr 81 0 2 0 0.00% 0.00% 0.00% 0 Dot11 auth Dot1x 82 4 1 4000 0.00% 0.00% 0.00% 0 Dot11 Mac Auth 83 0 2 0 0.00% 0.00% 0.00% 0 dot1x 84 0 2 0 0.00% 0.00% 0.00% 0 DTP Protocol 85 230368 11805797 19 0.00% 0.00% 0.00% 0 PI MATM Aging Pr 86 7336 1181676 6 0.00% 0.00% 0.00% 0 EtherChnl 87 0 1 0 0.00% 0.00% 0.00% 0 L2X Data Daemon 88 0 2 0 0.00% 0.00% 0.00% 0 EAPoUDP Process 89 393800 281203 1400 0.00% 0.00% 0.00% 0 IP Background 90 79896 198781 401 0.00% 0.00% 0.00% 0 IP RIB Update 91 8 6 1333 0.00% 0.00% 0.00% 0 PPP IP Route 92 0 6 0 0.00% 0.00% 0.00% 0 PPP IPCP PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 93 0 1 0 0.00% 0.00% 0.00% 0 Asy FS Helper 94 0 2 0 0.00% 0.00% 0.00% 0 SNMP Timers 95 16 2 8000 0.00% 0.00% 0.00% 0 SCTP Main Proces 96 0 1 0 0.00% 0.00% 0.00% 0 IUA Main Process 97 507500 11805828 42 0.00% 0.00% 0.00% 0 RUDPV1 Main Proc 98 0 1 0 0.00% 0.00% 0.00% 0 bsm_timers 99 212412 11805812 17 0.00% 0.00% 0.00% 0 bsm_xmt_proc 100 0 1 0 0.00% 0.00% 0.00% 0 CES Client SVC R 101 0 1 0 0.00% 0.00% 0.00% 0 IP Traceroute 102 46420 11805185 3 0.00% 0.00% 0.00% 0 Socket Timers 103 5356 51324 104 0.00% 0.00% 0.00% 0 TCP Timer 104 7252 3955 1833 0.00% 0.00% 0.00% 0 TCP Protocols 105 0 1 0 0.00% 0.00% 0.00% 0 COPS 106 8781468 23610370 371 0.08% 0.08% 0.06% 0 DHCPD Receive 107 0 2 0 0.00% 0.00% 0.00% 0 Dialer Forwarder 108 226188 197001 1148 0.08% 0.00% 0.00% 0 Adj Manager 109 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM Input 110 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM TIMER 111 1273684 371157 3431 0.00% 0.00% 0.00% 0 HTTP CORE 112 28680 196769 145 0.00% 0.00% 0.00% 0 IP Cache Ager 113 0 1 0 0.00% 0.00% 0.00% 0 RARP Input 114 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall 115 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 116 0 2 0 0.00% 0.00% 0.00% 0 PPP Bind 117 0 2 0 0.00% 0.00% 0.00% 0 PPP SSS 118 624048 117968981 5 0.00% 0.00% 0.00% 0 RBSCP Background 119 378288 2361290 160 0.00% 0.00% 0.00% 0 L2F management d 120 12 1 12000 0.00% 0.00% 0.00% 0 PPTP Mgmt 121 0 2 0 0.00% 0.00% 0.00% 0 PPTP Data 122 0 1 0 0.00% 0.00% 0.00% 0 Inspect Timer 123 3344 197006 16 0.00% 0.00% 0.00% 0 DHCPD Database 124 4815852 15156811 317 0.00% 0.00% 0.00% 0 CEF process 125 4 2 2000 0.00% 0.00% 0.00% 0 L2MM 126 0 1 0 0.00% 0.00% 0.00% 0 MRD 127 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN 128 0 2 0 0.00% 0.00% 0.00% 0 DDP 129 80 39404 2 0.00% 0.00% 0.00% 0 Authentication P 130 0 1 0 0.00% 0.00% 0.00% 0 Auth-proxy AAA B 131 0 1 0 0.00% 0.00% 0.00% 0 IPS Timer 132 0 2 0 0.00% 0.00% 0.00% 0 SDEE Management 133 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Inspect Tim 134 0 2 0 0.00% 0.00% 0.00% 0 URL filter proc 135 4 3 1333 0.00% 0.00% 0.00% 0 Crypto HW Proc 136 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA 137 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr 138 0 1 0 0.00% 0.00% 0.00% 0 Key chain liveke PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 139 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA 140 7036 7266 968 0.00% 0.00% 0.00% 0 LOCAL AAA 141 25636 16433 1560 0.00% 0.04% 0.01% 0 TPLUS 142 0 2 0 0.00% 0.00% 0.00% 0 VSP_MGR 143 100 2 50000 0.00% 0.00% 0.00% 0 CCVPM_HDSPRM 144 9560 4374681 2 0.08% 0.00% 0.00% 0 FLEX DSPRM MAIN 145 5432 4374679 1 0.00% 0.00% 0.00% 0 FLEX DSP KEEPALI 146 920 472846 1 0.00% 0.00% 0.00% 0 CRM_CALL_UPDATE_ 147 4 4 1000 0.00% 0.00% 0.00% 0 HDA DSPRM MAIN 148 195756 62663 3123 0.00% 0.00% 0.00% 0 Crypto Support 149 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc 150 0 3 0 0.00% 0.00% 0.00% 0 Crypto WUI 151 0 1 0 0.00% 0.00% 0.00% 0 CCSWVOICE 153 0 1 0 0.00% 0.00% 0.00% 0 http client proc 154 8 2 4000 0.00% 0.00% 0.00% 0 CCAAL2_CT 155 8 2 4000 0.00% 0.00% 0.00% 0 CCFRF11_CT 156 24 2 12000 0.00% 0.00% 0.00% 0 CCH323_CT 157 0 1 0 0.00% 0.00% 0.00% 0 CCH323_DNS 158 76 14 5428 0.00% 0.00% 0.00% 0 CCSIP_SPI_CONTRO 159 0 1 0 0.00% 0.00% 0.00% 0 CCSIP_DNS 160 16 13 1230 0.00% 0.00% 0.00% 0 CCSIP_UDP_SOCKET 161 8 1 8000 0.00% 0.00% 0.00% 0 CCSIP_TCP_SOCKET 163 4 1 4000 0.00% 0.00% 0.00% 0 QOS_MODULE_MAIN PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 164 0 1 0 0.00% 0.00% 0.00% 0 RPMS_PROC_MAIN 165 0 1 0 0.00% 0.00% 0.00% 0 VoIP AAA 166 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_HTSP 167 0 2 0 0.00% 0.00% 0.00% 0 VPM_MWI_BACKGROU 168 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_R2 169 8 13135 0 0.00% 0.00% 0.00% 0 FB/KS Log HouseK 170 3708 3616 1025 0.00% 0.00% 0.00% 0 Crypto ACL 171 0 1 0 0.00% 0.00% 0.00% 0 CRYPTO QoS proce 172 0 1 0 0.00% 0.00% 0.00% 0 Crypto INT 173 6347492 3105057 2044 0.00% 1.45% 1.35% 0 Crypto IKMP 174 31840 608440 52 0.00% 0.00% 0.00% 0 IPSEC key engine 175 0 1 0 0.00% 0.00% 0.00% 0 IPSEC manual key 176 4 3 1333 0.00% 0.00% 0.00% 0 Crypto PAS Proc 177 3704 7003 528 0.00% 0.00% 0.00% 0 Crypto Delete Ma 178 141452 1726406 81 0.00% 0.00% 0.00% 0 Key Proc 179 1956 5742 340 0.00% 0.00% 0.00% 0 crypto engine pr 180 24 4 6000 0.00% 0.00% 0.00% 0 Crypto CA 181 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL 182 0 1 0 0.00% 0.00% 0.00% 0 Crypto SSL 183 0 1 0 0.00% 0.00% 0.00% 0 DATA Transfer Pr 184 0 1 0 0.00% 0.00% 0.00% 0 DATA Collector 185 5588 9808 569 0.00% 0.00% 0.00% 0 AAA SEND STOP EV 186 0 3 0 0.00% 0.00% 0.00% 0 EEM ED CLI PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 187 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Counter 188 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Interface 189 0 3 0 0.00% 0.00% 0.00% 0 EEM ED IOSWD 190 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Memory-th 191 0 2 0 0.00% 0.00% 0.00% 0 EEM ED None 192 0 2 0 0.00% 0.00% 0.00% 0 EM ED OIR 193 4 2 2000 0.00% 0.00% 0.00% 0 EEM ED SNMP 194 800 197371 4 0.00% 0.00% 0.00% 0 EEM ED Timer 195 1268032 2364422 536 0.00% 0.00% 0.00% 0 EEM Server 196 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps 197 0 1 0 0.00% 0.00% 0.00% 0 PM Callback 199 220 3304 66 0.00% 0.00% 0.00% 0 IpSecMibTopN 200 0 2 0 0.00% 0.00% 0.00% 0 EEM Policy Direc 201 251244 98043 2562 0.00% 0.13% 0.12% 0 Syslog 202 0 1 0 0.00% 0.00% 0.00% 0 VPDN Scal 203 544600 11804264 46 0.00% 0.00% 0.00% 0 trunk conditioni 204 4 1 4000 0.00% 0.00% 0.00% 0 trunk conditioni 205 4 2 2000 0.00% 0.00% 0.00% 0 VLAN Manager 207 0 1 0 0.00% 0.00% 0.00% 0 TCP Driver 208 0 1 0 0.00% 0.00% 0.00% 0 TCP Listener 209 15240 9853 1546 0.00% 0.00% 0.00% 0 SSH Event handle 210 21708 409732 52 0.00% 0.00% 0.00% 0 CEF Scanner 211 37220 23079662 1 0.00% 0.00% 0.00% 0 IP NAT Ager PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 212 0 1 0 0.00% 0.00% 0.00% 0 IP NAT WLAN 213 25312 212165 119 0.00% 0.00% 0.00% 0 IP VFR proc 214 0 2 0 0.00% 0.00% 0.00% 0 IP Flow Backgrou 215 858880 368591958 2 0.00% 0.01% 0.00% 0 PPP manager 216 643840 368591964 1 0.00% 0.01% 0.00% 0 PPP Events 217 199208 11806265 16 0.00% 0.00% 0.00% 0 Multilink PPP 218 24 38 631 0.00% 0.00% 0.00% 0 IP SNMP 219 20 28 714 0.00% 0.00% 0.00% 0 PDU DISPATCHER 220 84 29 2896 0.00% 0.00% 0.00% 0 SNMP ENGINE 221 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro 222 0 1 0 0.00% 0.00% 0.00% 0 SNMP Traps 223 0 1 0 0.00% 0.00% 0.00% 0 NAT MIB Helper 224 28784 11821104 2 0.00% 0.00% 0.00% 0 NTP 225 481352 152244935 3 0.00% 0.03% 0.03% 0 IP SLA Mon Event
Come to think of it, the way the tunnel is setup is that it has 2 peers (2 ISPs), both being NAT addresses of the outside interface of the ASA. I have it configured as such on my 2621x router:
crypto isakmp policy 10 encr 3des hash md5 authentication pre-share group 2 crypto isakmp key somepassword address 10.1.1.1 crypto isakmp key somepassword address 20.1.1.1 ! crypto ipsec transform-set TUNNEL esp-3des esp-md5-hmac ! crypto map SDM_CMAP_1 1 ipsec-isakmp description SiteToSite Tunnel to Remote Site set peer 10.1.1.1 set peer 20.1.1.1 set transform-set TUNNEL match address 107
What this should do, I think, is that it will only connect to one peer, and if that fails, should connect to the other. The dynamics behind I don't know like its whoever gets connected first will be the endpoint or there is some priority. In anycase, each time I will only see one endpoint being connected but is the traffic being "split" in half between the two? Is that why it would be slow?
Not sure exactly what would happen there, I would suspect that the first match would come up and the 2nd might never come up. This more than likely is not the cause of your frustrations however.
-Wil
psychogenic wrote:
Regarding ping time:-
How far apart are your devices?
200ms is OK for say California to Europe.
If they are nearer:- The usual cause for this is for a packet queue to have formed somewhere.
Since your CPU is only 30% the router looks OK.
My guess is that your T1 is full.
sh int and look at the "rate".
Note that the "5 min" rate includes data for over 15 mins.
I also guess that it is not full of crypto traffic since as has been said a 2600 is not very good at crypto. However it may do the job you want. You say 2621x - a 2621 is quite a bit faster than a 2611 and if I recall correctly an XL quite a bit faster again.
"CPU utilization for five seconds: 29%/27%; one minute:
30%; five minutes: 28% "
29%/27% further supports the ides that the router is NOT doing much crypto.
This means that the TOTAL load is 29% of which 27% is "fast switching" packets. This is all good.
Just my suggestion out of all that the other guys gave you is to have a look to the debugs enabled.
HTH Alex.
Thanks all for the generous help.
Local site is New York and remote site is Romania. However I have exisitng VPN tunnels between myself and France and the UK and both ping times are twice as responsive. :(
I checked the debug logs and did not notice anything out of the ordinary as well. At least from what I could see.
To the OP. I am in London and the RTT to www.unibuc.ro [80.96.21.9] is 52ms minimum. We are an ISP (v.small) with good connectivity.
Maybe your links are wandering about a bit. We had a link to the US from London that went via Spain a while back. 100ms RTT Lon - NY.
Maybe yours goes via Africa, or Poland.
tracert 80.96.21.9 to protect the guilty
8 3 ms 4 ms 3 ms ldn-b3-geth2-0.telia.net [213.248.100.141] 9 3 ms 3 ms 3 ms ldn-bb1-pos6-1-0.telia.net [213.248.65.237] 10 18 ms 18 ms 17 ms hbg-bb1-link.telia.net [80.91.249.11] 11 37 ms 37 ms 37 ms bpt-b2-link.telia.net [213.248.64.18] 12 38 ms 37 ms 37 ms dante-109059-bpt-b2.c.telia.net [213.248.103.62] 13 * * * Request timed out. 14 51 ms 51 ms 51 ms 217.73.160.209 15 52 ms 51 ms 52 ms 217.73.160.213 16 53 ms 53 ms 52 ms 141.85.5.130 17 56 ms 53 ms 52 ms www.unibuc.ro [80.96.21.9]
Sometimes you can get an idea of the locations from the router names. ldn is definately London hbg ? Hamburg, Heidleburg (spelling? sorry)
