voip question, call reject in gatekeeper
May 03, 2005 1 Replies
Hi all,
as a beginner, i'd like to ask how to reject certain calls on a cisco
7200. i assume it can be done via the gatekeeper: i'd like to discard calls that have a certain called number.
i started looking through cco docs, but the match-list does not seem to be the solution.
thanks adam
If it is an H.323 Gatekeeper you could just add:
arq reject-unknown-prefix
And not define the prefix in a zone.
Jonathan
You could do it with a
