Very slow ftp on ASA 5510
Aug 08, 2006 1 Replies
Hello,
I have annoying problem with ftp. I have: ASA 5510 with active IPS. In DMZ I have several servers. Every day I have to puts many files via ftp from workstations in LAN connected to ASA inside interface. Connection work fine, but for each one file ftp client waits ~60 secounds after transmission. When I have turned off the IPS everythings work fine. I did several test with IPS rules and any give correct results. Example: I turned off every rules for FTP.
Could you tell me what is wrong with ASA or IPS configuration?
Best regards Arek
Sniff the traffic on both ends with the IPS turned on and with it off and compare the results. I would expect it's something like the packets needed for PMTU to function are blocked or some other similar thing. Sniffing the traffic will give you a better idea though.
J
