Two PIX + router networking
Sep 26, 2005 2 Replies
My network:
SiteA (PIX506E) -- > Site B( PIX 515E + RouterB ) --- > Router C
The Network between Site A + Site B = PIX VPN tunnel The Network between Site B + Site C = IPLC
How can I configure teh PIX so that User Site A users can access the network resources in Site C ?
Thank you so much Benson
:My network:
:SiteA (PIX506E) -- > Site B( PIX 515E + RouterB ) --- > Router C
:The Network between Site A + Site B = PIX VPN tunnel :The Network between Site B + Site C = IPLC
IPLC? International Private Leased Circuit?
:How can I configure teh PIX so that User Site A users can access the :network resources in Site C ?
Figure out the IP addresses of the resources on Site C as known to Site C. Now, add those IP addresses to the crypto map match address ACL that forms the VPN, and add them to the nat 0 access-list ACL that turns off NAT'ing for the VPN.
Thank you so much for your reply,
Yes, the network SiteB + SiteC is an IPLC Line.
at SiteC, the IP address = 172.28.0.0 /16 at SiteB, the IP address = 172.27.0.0 / 16 at SiteA, the IP address = 172.27.28.0/24
Users at sitA can access the resources in SiteB without problem, but they can not go to SiteC
When I triedt to ping Site C subnets from Site A, there is no reply like the following result:
( by using Ethereal ) Source Destination Protocol Info
172.27.28.55 172.28.0.11 ICMP Echo (ping) Request repeat..
So, no Echo(ping)reply...Do you know what the problem is ?
On the other side, by using "tracert", always timeout....
I also tried to add all IP subnets to the NAT0...and teh VPN ACL..but in vain.
So, need your help..
Thank you Benson
