I ahve several router in a test bed, however I need to simulate
80-100ms latency between the links, either serial or ethernet. Are there any tools to do this?
Tx
I just installed NISTNet on a PC with 2 nics and Fedora 4 and it works pretty well. I had to simulate a 140ms delay for a connection from Wisconsin to Czech Republic for app testing. Here is what I did: TestPC-2611Router-DTE/DCESerialCable-2621Router-NISTNet-CoreNetwork The…
Read the full replyI ahve several router in a test bed, however I need to simulate
Tx
Lowering the speed of the serial lines can significantly increase the delay.
DT
There are a bunch of software tools you can run of a PC etc to sinthesize a delay, but you then would need serial interfaces card or to use ethernet
you can find these by searching google.
i prefer dedicated hardware to do this since that way it doesnt vanish from the lab when i dont use it for a while :)
i have used a hardware box designed to simulate anything up to satellite delays (much cheaper than a satellite link!) - 1st came across this when we were debugging a satellite link.
i like this one as you can just alter the delay and error rate on the front panel
a few 1000 UK pounds - YMMV - i havent spent money on them for a while.
E1 (G.703) interfaces cost extra.
The serial connection allows me to adjust clock rate to adjust serialization delay. This is important because here is how my results varied:
Real Circuit:
32 byte ping 140ms 1400 byte ping 156msTest w/384000 clock rate:
32 byte ping 139ms 1400 byte ping 193msTest w/1300000 clock rate:
32 byte ping 139ms 1400 byte ping 153msHave something to add? Share your thoughts — no account required.
