Setting up QOS on 831 for VoIP
Apr 09, 2006 1 Replies
I have a Cisco 831 Router running code version 12.3. I am trying to setup QOS for VoIP (using SunRocket). I have set a couple things up, but while I'm talking if I do an upload test quality is terrible. Downstream is fine even during a test.
I have Charter as my ISP, and I consistently get 2.9 Mb down/240 Kb up using Speakeasy's test.
Here is my current config:
Current configuration : 2077 bytes ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname Thomas ! logging buffered 4096 informational enable secret 5 xxxx enable password 7 xxxx ! no aaa new-model ip subnet-zero ip dhcp excluded-address 192.168.2.4 ip dhcp excluded-address 192.168.2.5 ip dhcp excluded-address 192.168.2.106 ! ! ip audit notify log ip audit po max-events 100 no ftp-server write-enable ! ! ! ! ! ! class-map match-all voice match ip precedence 5 ! ! policy-map LLQ class voice priority 300 class class-default fair-queue policy-map shape class class-default shape average 3250000 service-policy LLQ ! ! ! interface Ethernet0 ip address 192.168.2.1 255.255.255.0 ip nat inside service-policy output shape ! interface Ethernet1 ip address dhcp ip nat outside duplex auto ! ip nat inside source list 102 interface Ethernet1 overload ip nat inside source static tcp 192.168.2.4 21 interface Ethernet1 21 ip nat inside source static tcp 192.168.2.4 80 interface Ethernet1 80 ip nat inside source static tcp 192.168.2.4 6000 interface Ethernet1
6000 ip nat inside source static udp 192.168.2.4 177 interface Ethernet1 177 ip nat inside source static tcp 192.168.2.4 20 interface Ethernet1 20 ip nat inside source static tcp 192.168.2.4 22 interface Ethernet1 22 ip nat inside source static tcp 192.168.2.5 8180 interface Ethernet1
8180 ip nat inside source static tcp 192.168.2.106 3389 interface Ethernet1
3389 ip nat inside source static tcp 192.168.2.106 5800 interface Ethernet1
5800 ip nat inside source static tcp 192.168.2.106 5900 interface Ethernet1
5900 ip nat inside source static tcp 192.168.2.5 80 interface Ethernet1 81 ip classless no ip http server no ip http secure-server ! access-list 102 permit ip 192.168.2.0 0.0.0.255 any dialer-list 1 protocol ip permit ! line con 0 no modem enable line aux 0 line vty 0 4 exec-timeout 120 0 password 7 xxxx login length 0 ! scheduler max-task-time 5000 ! end
It seems to me that you only have the QOS policy applied one way. Output on your LAN port would indicate that you are shaping on Downloads. If you want to shape on uploads, apply a QOS policy output on E1 as well. However, you may wish to create a new policy due to the fact that your connection is not symetrical.
Hope that helps,
Jim
