Router for Fractional T3
Sep 12, 2006 2 Replies
Hope someone could point me in the right direction on purchasing the right router. We are upgrading to a Fractional T3 line (12Mbps). We have about 50 site offices that currently connect to the main office with SOHO/VPN routers. What are my cost effective options?
Cisco 7145 was recommended but its end of life Cisco 3845 was also recommended but expensive
I am new to the cisco world and hopefully somebody can shed some light.
thanks in advance
ZooO
You may wish to speak one-on-one with your local Cisco Pre-Sales Representative:
Your local Cisco Registered Partner / Reseller:
The Cisco Solution Designer:
Cisco Solution Finder for Modular Routers:
Furthermore, you may find financially advantageous, Factory Refurbished Cisco with Warranties Same as New, Fully Licensed and SMARTnet Eligible:
Sincerely,
Brad Reese BradReese.Com - Cisco Jobs
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Resumes
I'd pick a 7200 over the 7145 anyway.
Yep. 3845, or higher end 2800 would be a good choice.
How about a used 7200 relicensed for use? Fairly cheap on the used market. The license cost is a bit, but not too bad.
