reverse route injection maintenance
Apr 23, 2008 9 Replies
Most relevant reply
kicker4
Thanks for the response... I was able to clear mine with a reboot of the box and I've not seen them come back yet. Hopefully it stays that way, but I'll be reading the release notes to see if it's mentioned! rg
Hi all,
posted a while back on issues of 'reverse routes' not being removed from an IOS (12.4) routing table, and no reply back so please help !
This is question re maintenance of the static routes that are dynamically inserted when we have the "REVERSE ROUTE" configuration in the dynamic crypto map.
IOS version - c1700-advsecurityk9-mz-124-17a.bin
VPN clients - Cisco vpn clients v4.6
the expected behaviour is that the static route to the IP address that is 'leased' by the vpn client by way of "ip local pool' configuration via the (public) IP address of the vpn client would be removed when the IPSEC SA is torn down or timed out by the IOS vpn server.
the observed behaviour is that instead of any of these routes being removed, another route to the leased IP address is added via the public address of the next VPN client that leases that IP address such that a sample of the output from 'show ip route' gives us;
192.168.2.10 [1/0] via 86.145.45.34 via 86.140.228.10 .......
192.168.2.8 [1/0] via 87.56.23.34 via 78.56.42.34 via 89.34.62.23 ....
etc for all the IP addresses in the local pool.
this is even though the destination IP addr is freed from the IP pool, and the IPsec SA should no longer be valid.
Help in this will be gladly received.
Merv, thanks for note;
i insert the crypto configuration here which i think is the pertinent config - if any other is needed let me know
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set ESP-3DES-SHA
reverse-route
crypto map SDM_CMAP_1 client authentication list sdm_vpn_xauth_ml_1
crypto map SDM_CMAP_1 client accounting list acct_list_2
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 client configuration address respond
crypto map SDM_CMAP_1 10 ipsec-isakmp
set peer Q.W.E.R
set transform-set ESP-3DES-SHA1
match address 110
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
If the RRI created routes are still there after the IPSEC SA for the peer expires then that is a bug
Check that the IPSEC SA's are being removed after the VPN client disconnects
ipsec SA's are being removed such that they do not appear in 'show crypto ipsec sa"
however, what is 'interesting' is that the peers that should no longer be valid seem to be retained perhaps in the SA table ? such that they are listed (but with no spi, transform etc ..) in the output of;
'show crypto ipsec sa address'.
this indicates to me that perhaps they are not in fact being 'purged' from the SA table ?,
If you have SmartNet on the unit, then suggest you open a case with the Cisco TAC
Just curious if there was any sort of solution to this... I'm seeing the exact same issue.
none received i am afraid
would seem a bug, poss on account of these routes being associated with not 'real' interfaces, and as such not being managed correctly.
looking at virtual tunnel interfaces, which hopefully support dynamic clients and routes that are managed correctly as interfaces / aka ipsec tunnels go up and down
rg
the observed behaviour in my case, was that while router reload did flush these routes, they would return and not be removed as would be expected.
