Re: PIX 525 and SSL
Jan 20, 2006 3 Replies
Jump to replies (3)
Hi, Does the Cisco PIX support SSL encryption to be used like for example in the following setup:
HOST A -------------> PIX -------------> HOST B SSL Clear Text port 443 port 7777
How would the config look for something like this? Thanks
-- Matteo
Not in PIX 6.x. If I recall correctly, it could be done in PIX 7.0, which is supported on the PIX 525.
Walter, Would you know the command to enable this or to start configuring it. Or if you can tell me what this is called so that I can search for documentation. Thanks
--Matteo
snipped-for-privacy@hushmail.com (Walter Roberson) wrote in news:yv_zf.180842$tl.69338@pd7tw3no:
It appears the configuration guideance documentation is at
