Problem with Exchange server behind PIX firewall
Apr 07, 2006 2 Replies
Can anyone help me with my PiX firewall. There is an Exchange server
192.168.2.11 inside. The outbound emails are blocked and can not reach outside! Can anyone figure out where is my mistake in the configuration file. I will appreciate any help!
There is the configuration: PIX Version 6.1(1) nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password /JFKHFKFK encrypted passwd GLggGLGLlkJHG encrypted hostname NRP-PIX fixup protocol ftp 21 fixup protocol http 80 fixup protocol h323 1720 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol sip 5060 fixup protocol skinny 2000 names access-list inside_access_out permit tcp any any eq smtp access-list inside_access_out permit tcp any any eq www access-list inside_access_out permit tcp any any eq 443 access-list inside_access_out permit tcp any any eq 3389 access-list inside_access_out permit tcp any any eq domain access-list inside_access_out permit udp any any eq domain access-list inside_access_out permit tcp any any eq 1776 access-list inside_access_out permit tcp any any eq ftp access-list inside_access_out permit icmp any any echo access-list inside_access_out permit tcp any any eq 8080 access-list inside_access_out permit tcp any any eq 2443 access-list vpnacl permit ip 192.168.2.0 255.255.255.0 10.1.1.0
255.255.255.0 pager lines 24 logging on logging trap notifications logging history notifications logging facility 0 logging host inside 192.168.2.12 interface ethernet0 auto interface ethernet1 auto mtu outside 1500 mtu inside 1500 ip address outside 206.158.XYZ.69 255.255.252.0 ip address inside 192.168.2.2 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool clientpool 10.1.1.10-10.1.1.36 pdm history enable arp timeout 14400 global (outside) 1 206.158.XYZ.105 netmask 255.255.252.0 global (outside) 1 206.158.XYZ.104 netmask 255.255.252.0 nat (inside) 0 access-list vpnacl nat (inside) 1 192.168.2.0 255.255.255.0 0 0 static (inside,outside) 206.158.XYZ.99 192.168.2.11 netmask
255.255.255.255 0 0 access-group inside_access_out in interface inside conduit deny ip any host 81.48.75.223 conduit permit ip any 141.152.97.32 255.255.255.224 conduit permit tcp host 206.158.107.99 eq smtp any conduit permit tcp host 206.158.107.99 eq www any conduit permit tcp host 206.158.107.99 eq domain any conduit permit ip host 206.158.107.99 host 141.152.97.35 route outside 0.0.0.0 0.0.0.0 206.158.XYZ.1 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323
0:05:00 si p 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ (inside) host 192.168.2.10 secretkey timeout 5 aaa-server RADIUS protocol radius aaa-server LOCAL protocol tacacs+ aaa-server mytacacs protocol radius no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps tftp-server inside 192.168.2.10 tftp floodguard enable sysopt connection permit-ipsec no sysopt route dnat crypto ipsec transform-set myset esp-des esp-md5-hmac crypto dynamic-map dynmap 20 set transform-set myset crypto map newmap 20 ipsec-isakmp dynamic dynmap crypto map newmap interface outside crypto map vpngroup client authentication TACACS+ isakmp enable outside isakmp policy 10 authentication pre-share isakmp policy 10 encryption des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup Isis address-pool clientpool vpngroup Isis dns-server 192.168.2.10 vpngroup Isis wins-server 192.168.2.10 vpngroup Isis default-domain nrpharma.com vpngroup Isis split-tunnel vpnacl vpngroup Isis idle-time 1800 vpngroup Isis password ******** vpngroup svinzant address-pool clientpool vpngroup svinzant dns-server 192.168.2.10 vpngroup svinzant wins-server 192.168.2.10 vpngroup svinzant default-domain nrpharma.com vpngroup svinzant split-tunnel vpnacl vpngroup svinzant idle-time 1800 vpngroup svinzant password ******** telnet 192.168.2.0 255.255.255.0 inside telnet timeout 10 ssh timeout 5
in my experience, "fixup protocol 25" is really buggy & tends to screw up email.
try:
no fixup protocol smtp 25
and see how exchange behaves.
Are you seeing this dropped in the Pix logs? Are there any hits against the outbound acl? Is the server trying to use a smart host to relay through or is it resolving via DNS?
Chris.
