Problem setting of PIX 501 - no internet access
Dec 17, 2007 1 Replies
Hello,
The PIX 501 is connected to ISP via PPPoE conection and internal DHCP. All connections are OK, but it is not possible to access the Internet from internal clients.
Any idea what settting should be checked/changed ?
I have all the settings in one pdf file and can send them.
Thanks in advance for your time.
Borislav
Post a "show ip address" and a "show config". Common issues: forgetting to use the setroute command on your outside interface or not setting up NAT correectly.
