PIX 506E PDM 3.0(1) PIX 6.3(3) NAT/PAT (Part 2)
Aug 22, 2006 2 Replies
PIX 506E PDM 3.0(1) PIX 6.3(3) NAT/PAT (Part 2) open original image
Hello,
I have finally the Cisco up and running, though i have one problem. I have an VPN server behind the PIX. I was able to add a translation rule for TCP port 1723, but not for GRE... Anyone an idea how to do so...?
Sincerely, Michiel
Situation : I have as a modem the Zyxel Prestige 660HW wich is used as modem, but it will NAT the public ip.
Zyxel WAN : Internet (public ip natted, DMZ is 192.168.168.2) LAN : 192.168.168.1 mask 255.255.255.252
Cisco WAN : 192.168.168.2 mask 255.255.255.252 LAN : 192.168.68.8 mask 255.255.255.0
You will have to make a one to one NAT translation between the VPN server and the external IP
static(inside,outside)
Then create the ACL
access list 10 permit GRE any
Apply the ACL to interface
Hello Chad,
I have done the following, i not added the thing you said, i looked at the Cisco link you gave me. And i have added the following rule "fixup protocol pptp 1723-1723" that made it working, though i already had added those rules to accept incomming traffic.
Thanks for the link!
Sincerely, Michiel
