Opening up port 443
Oct 12, 2006 1 Replies
I have a website that I need to enable https on.
The firewall is already configured for port 80(www), but I just configured it for port 443(https) as well.
The below is the new config with the https line added. I was just wondering(hoping!) that I did it right.
Does anyone see any errors?
Thanks, CMT
Cisco PIX 506e
static (inside,outside) tcp 1.1.1.1 www 192.168.0.2 www netmask
255.255.255.255 0 0 static (inside,outside) tcp 1.1.1.1 https 192.168.0.2 https netmask
255.255.255.255 0 0
What you showed was fine. Note though, that you will also need to edit the access-list you have applied to the outside interface.
show access-group
and find the one marked with 'in interface outside'. The name (or number) after the 'access-group' keyword is the name of the access-list you need to change.
