Noise on VoIP Circuit
Dec 07, 2005 0 Replies
Hi all,
We have a number of 1761s all fitted with four VIC2EMs, some are fitted with PVDM 16s and some are fitted with one PVDM4 and one PVDM12. Those routers fitted with a 4 & 12 will occasionally transmit as loud warbling noise over the Network to the other router. The noise can only be silenced by a "shut" "no shut" on the voice port.
Is this a symptom of a single circuit being split over the two PVDMs?
Has anyone any Ideas?
Thanks for any help
Paul
