Hi All,
I'm a bit lost atm and could do with some help.
Am trying to get static entries to function. These used to work but stopped - cannot remember if I made any changes. At the mo any incomming connections are not forwarded.
Any help appreciated.
Thanks, S.C.
! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname 2611 ! boot-start-marker boot-end-marker ! enable password ******************* ! no aaa new-model ip subnet-zero ip cef ! ! no ip ftp passive ip ftp username ********************* ip ftp password ********************* no ip domain lookup no ip dhcp conflict logging ip dhcp excluded-address 192.168.0.1 192.168.0.60 ip dhcp excluded-address 192.168.0.70 192.168.0.254 ! ip dhcp pool dhcp1 network 192.168.0.0 255.255.255.0 default-router 192.168.0.254 dns-server 62.42.230.24 62.42.63.52 ! ! ! ! ! interface Ethernet0/0 mac-address 0010.c6e2.ac32 ip address dhcp ip access-group 1 in ip access-group 1 out ip nat outside half-duplex ! interface Serial0/0 no ip address shutdown ! interface Ethernet0/1 ip address 192.168.0.254 255.255.255.0 ip access-group 1 in ip access-group 1 out ip nat inside half-duplex ! ip nat inside source list 10 interface Ethernet0/0 overload ip nat inside source static tcp 192.168.0.61 80 interface Ethernet0/0
80 ip nat inside source static udp 192.168.0.61 69 interface Ethernet0/0
69 ip nat inside source static tcp 192.168.0.30 21 interface Ethernet0/0
21 ip nat inside source static udp 192.168.0.30 11025 interface Ethernet0/0 11025 ip nat inside source static tcp 192.168.0.30 11025 interface Ethernet0/0 11025 ip nat inside source static tcp 192.168.0.30 13454 interface Ethernet0/0 13454 ip nat inside source static tcp 192.168.0.30 1025 interface Ethernet0/0 1025 ip nat inside source static udp 192.168.0.30 1025 interface Ethernet0/0 1025 ip http server ip classless ip route 0.0.0.0 0.0.0.0 Ethernet0/0 ! ! access-list 1 permit any access-list 10 permit 192.168.0.0 0.0.0.255 ! line con 0 line aux 0 line vty 0 4 password ******************** login line vty 5 15 password ***************** login ! ! end
