Must both key-id and key-string be same when authenticating?
May 29, 2007 2 Replies
HACabrera
No, It cannot be used. In order for you to authenticate a peer, both key-string and key-id have to be the same in both peers. I.E.- R1 ---------- R2 On R1: (key1=abc, key2=def, key3=xyz) On R2: (key1=abc, key2=def, key3=xyz) See you!!! HACabrera
Hello,
If each router is configured to use key chain to authenticate each other, must both key-id and key-string be same? For example, R1 --------------- R2. On R1: (key1=abc, key2=def, key3=xyz) On R2: (key1=xyz, key2=abc, key3=def) They have same key-strings, but different key-ids, Can this configuration be used?
Thanks.
See you!!!
HACabrera
