mkdir not available.
May 10, 2006 1 Replies
Why my stupid IOS doesn't recognize mkdir? How can I create a directory in the flash: device?
Version 12.3(8)YA1
The Cisco Command Lookup Tool reports 2 commands with two references
CF-358 it says the command is available from 11.3AA FR-206 it says the command is available from 11.3AA
So what's the problem?
TIA Alex.
The mkdir command is only valid on Class C Flash file systems.
Usually found on high-end routers and switches.
