Maximum active IPSec sessions
Oct 11, 2005 1 Replies
I believe that prior to PIX 7.0 OS, it was not possible to restrict the limit of active IPSec sessions that terminate on a PIX. Right?
In article , paras wrote: :I believe that prior to PIX 7.0 OS, it was not possible to restrict the :limit of active IPSec sessions that terminate on a PIX. Right?
If you were using RADIUS/TACACS+ to authenticate the sessions, then in theory you could have the success depend upon the number of other sessions. There is, though, some question about whether you can reliably detect the end of sessions with this mechanism.
It isn't a built-in PIX 6.x feature.
