Logging of ESP packets required?
May 20, 2005 1 Replies
anybody43
The LOG keyword may be forcing some packets to be process switched that would otherwise be fast switched using your preferred fast switching poison. You can force process switching with no ip route-cache on the interfaces. You could try this instead of log. If that "works" call…
Logging of ESP packets required? open original image
I set up my VPN on a Cisco router 1711 running IOS 12.2(15)ZL1. Everything works fine but I need to log incoming ESP packets from the client, otherwise the router does not respond to those packets.
permit esp any host 2.2.2.2 NO RESPONSE permit esp any host 2.2.2.2 log WORKS
I wonder why "log" is required. Thanks for any hints.
If that "works" call Cisco 'cos its a bug.
What _Exactly_ is 12.2(15)ZL1 ????????
If it supports your requirements move to a "mainline" release. i.e. 12.x(y) with NO successive letters.
OR failing that:- the "T" train.
12.x(y)T
Read about the IOS release process and look at the IOS roadmap.
Sorry if you are not a "customer".
