Learner ACL question
Nov 21, 2006 2 Replies
Will anyone help me with the syntax needed to prevent smtp traffic leaving the lan unless its from one of the two email servers?
Is it permit host (emailserver1 IP) host any eq 25 permit host (emailserver2 IP) host any eq 25 deny host any host any eq 25
or permit host (emailserver1 IP) host any eq smtp permit host (emailserver2 IP) host any eq smtp permit host any host any eq smtp
and does it have to be an extended acl? Its a Cisco 837 by the way, with default installation OS from about 3 years ago. I'm not using the email servers to receive email directly, so I only want email to leave, I'm not using PAT to open it up to two way traffic.
Thanks in advance for your help, SW
ip access-list extended blocksmtp permit tcp host x.x.x.x any eq 25 permit tcp host y.y.y.y any eq 25 deny tcp any any eq 25 permit ip any any
You need the last 'permit', otherwise you'll block all other traffic (implicit 'deny all' at the end of every ACL). You can apply it to the ethernet as an inbound ACL:
interface FastEthernet0 ip access-group blocksmtp in
And yes, since you're looking to match a particular TCP port, it has to be an extended ACL.
Tom,
Thanks a lot for your help. That did the trick. I now have another question, but I'll start a new thread.
Regards, SW
