Kindly help me with this PIX problem
Jul 29, 2006 7 Replies
Jump to replies (7)
Why can't I ping the host 209.178.196.211? Please see the config below. The IP belongs to a Windows 2000 mail server. Because it is blocked by PIX, our company cannot send or receive email. I called the ISP (Wave2Wave) and they are atrocious. Even though they have set up the firewall several years ago, they don't assume any responsibility for it. So I am left to trouble shoot this. I don't have any CISCO training. I am a software programmer. I tried to learn PIX as much as I can and now it is way above my head. I was told to post here to get the attention of experts in CISCO appliances. I am earnestly hoping someone will read this and respond with some logic. I am sorry for starting multiple threads. I need help desperately. Kindly let me know any comments by replying to this thread. I won't be able to access the PIX until Monday. That is another issue. The PIX has an outside IP of
209.178.196.210 (please see the config below). When I telnet to it using Putty (secure shell) there was no response. However, if someone has a solution to my problem, I will able to implement it in the weekend. Once again I apologize for starting multiple threads. Many thanks for reading this post.
: Saved : PIX Version 6.1(1) nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password 9Hxv6QfoEUwhwV2T encrypted passwd 9Hxv6QfoEUwhwV2T encrypted hostname iexpect-corp fixup protocol ftp 21 fixup protocol http 80 fixup protocol h323 1720 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sqlnet 1521 fixup protocol sip 5060 fixup protocol skinny 2000 fixup protocol smtp 25 names name 192.168.5.10 corp-smtp name 192.168.5.13 njrep1 name 192.168.5.150 trig1 name 192.168.5.151 trig2 name 192.168.5.61 brett name 192.168.5.58 sfg name 192.168.5.152 sfg2 name 192.168.5.63 pepsanchez name 192.168.5.9 corp-smtp2 access-list ipsec permit ip 192.168.5.0 255.255.255.0 10.0.255.0
255.255.255.0 access-list ipsec permit ip 192.168.11.0 255.255.255.0 10.0.255.0
255.255.255.0 access-list incoming permit tcp any host 209.178.196.211 eq smtp access-list incoming permit tcp any host 209.178.196.212 eq smtp access-list incoming permit tcp any host 209.178.196.211 eq 5631 access-list incoming permit tcp any host 209.178.196.211 eq 5632 access-list incoming permit udp any host 209.178.196.211 eq 5632 access-list incoming permit udp host 216.34.112.198 eq dnsix any access-list incoming permit udp host 216.33.202.54 eq dnsix any access-list incoming permit tcp any eq telnet host 216.74.138.147 access-list incoming permit tcp any host 209.178.196.212 eq telnet access-list incoming permit tcp any eq telnet host 209.178.196.212 access-list incoming permit tcp any host 209.178.196.211 eq www access-list incoming permit tcp any host 209.178.196.212 eq www access-list incoming permit tcp any host 209.178.196.212 eq ftp access-list incoming permit tcp any eq ftp host 209.178.196.212 access-list incoming permit tcp any host 209.178.196.213 eq 22 access-list incoming permit tcp any host 209.178.196.213 eq www access-list incoming permit tcp any host 209.178.196.211 eq 3389 access-list incoming permit tcp any host 209.178.196.212 eq 3389 access-list incoming permit tcp any host njrep1 eq 22 access-list incoming permit tcp any host njrep1 eq ftp access-list incoming permit tcp any host 209.178.196.215 eq 4662 access-list incoming permit udp any host 209.178.196.215 eq 4672 access-list incoming permit tcp any host 209.178.196.217 eq www access-list incoming permit tcp any host 209.178.196.213 eq 443 access-list incoming permit tcp any host 209.178.196.217 eq 22 access-list incoming permit tcp any host 209.178.196.222 eq 5900 access-list incoming permit tcp 202.138.142.224 255.255.255.224 host
209.178.196.216 eq 443 access-list incoming permit tcp any host 209.178.196.217 eq 443 access-list incoming permit tcp any host 209.178.196.222 eq www access-list incoming permit tcp any host 209.178.196.222 eq 129 access-list incoming permit tcp any host 209.178.196.222 eq 132 access-list incoming permit tcp any host 209.178.196.211 eq ftp access-list incoming permit tcp any host 209.178.196.216 access-list incoming permit icmp any host 209.178.196.222 access-list incoming permit tcp any host 209.178.196.211 access-list incoming permit icmp any host 209.178.196.211 access-list outgoing permit tcp any any access-list outgoing permit icmp any any access-list outgoing permit icmp any any echo-reply access-list outgoing permit udp any any access-list outgoing permit tcp any any eq www access-list outgoing permit tcp any host 216.239.35.101 eq www access-list outgoing permit udp any host 216.34.112.198 eq dnsix access-list outgoing permit udp any host 216.33.202.54 eq dnsix pager lines 24 logging on interface ethernet0 10baset interface ethernet1 10baset mtu outside 1500 mtu inside 1500 ip address outside 209.178.196.210 255.255.255.240 ip address inside 192.168.5.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool corp-home 192.168.99.1-192.168.99.224 pdm history enable arp timeout 60 global (outside) 1 209.178.196.220-209.178.196.221 global (outside) 1 209.178.196.219 nat (inside) 1 0.0.0.0 0.0.0.0 0 0 alias (inside) sfg 209.178.196.216 255.255.255.255 alias (inside) sfg2 209.178.196.217 255.255.255.255 alias (inside) corp-smtp 209.178.196.211 255.255.255.255 alias (inside) 192.168.11.150 209.178.196.213 255.255.255.255 alias (inside) 192.168.5.149 209.178.196.222 255.255.255.255 static (inside,outside) 209.178.196.213 trig1 netmask 255.255.255.255 0
0 static (inside,outside) 209.178.196.214 trig2 netmask 255.255.255.255 0
0 static (inside,outside) 209.178.196.211 corp-smtp netmask
255.255.255.255 0 0 static (inside,outside) 209.178.196.215 brett netmask 255.255.255.255 0
0 static (inside,outside) 209.178.196.216 sfg netmask 255.255.255.255 0 0
static (inside,outside) 209.178.196.217 sfg2 netmask 255.255.255.255 0
0 static (inside,outside) 209.178.196.222 192.168.5.149 netmask
255.255.255.255 0 0 static (inside,outside) 209.178.196.218 pepsanchez netmask
255.255.255.255 0 0 static (inside,outside) 209.178.196.212 corp-smtp2 netmask
255.255.255.255 0 0 access-group incoming in interface outside route outside 0.0.0.0 0.0.0.0 209.178.196.209 1 route inside 192.168.11.0 255.255.255.0 192.168.5.2 1 route inside 192.168.254.0 255.255.255.0 192.168.5.2 1 timeout xlate 3:00:00 timeout conn 3:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323
0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server RADIUS protocol radius http server enable http corp-smtp2 255.255.255.255 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt ipsec pl-compatible no sysopt route dnat crypto ipsec transform-set iexpect esp-des esp-md5-hmac crypto ipsec transform-set myset esp-des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map corp 1 ipsec-isakmp crypto map corp 1 match address ipsec crypto map corp 1 set peer 216.74.138.157 crypto map corp 1 set transform-set iexpect crypto map corp 10 ipsec-isakmp dynamic dynmap crypto map corp client configuration address initiate crypto map corp client configuration address respond crypto map corp interface outside isakmp enable outside isakmp key ******** address 216.74.138.157 netmask 255.255.255.255 isakmp identity address isakmp policy 1 authentication pre-share isakmp policy 1 encryption des isakmp policy 1 hash md5 isakmp policy 1 group 1 isakmp policy 1 lifetime 86400 isakmp policy 10 authentication pre-share isakmp policy 10 encryption des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup corphome address-pool corp-home vpngroup corphome dns-server 192.168.1.6 vpngroup corphome wins-server 192.168.1.6 vpngroup corphome default-domain corp.iexpect.com vpngroup corphome idle-time 1800 vpngroup corphome password ******** telnet corp-smtp 255.255.255.255 inside telnet 192.168.5.2 255.255.255.255 inside telnet 192.168.11.0 255.255.255.0 inside telnet 192.168.5.0 255.255.255.0 inside telnet njrep1 255.255.255.255 inside telnet corp-smtp2 255.255.255.255 inside telnet timeout 5 ssh njrep1 255.255.255.255 inside ssh timeout 5 terminal width 80 Cryptochecksum:b74f20411172389725f6e85195e68c9b
Like I said in the firewalls newsgroup, you have a very old PIX operating system and there are known bugs in the NAT translation in that version.
Inability to ping an IP address does not affect ability to send or receive email. It is NOT part of the smtp protocol to ping an address before attempting to connect to it on tcp port 25.
Always a better idea than posting in the general firewalls newsgroup; there are more people here who are familiar with PIX and something might occur to one person that the other people missed.
Alas, I appear to be the resident PIX 6 expert, and I'm the one who told you that you really need a software upgrade.
You cannot telnet to the outside interface of a PIX 6 firewall (at least not without VPN layers that are not present in your configuration.) You *can* ssh to the outside interface of a PIX 6 firewall, if you have set up a few things ahead of time. In particular,
That command allows ssh to the PIX, but only from the host njrep1 on the -inside- interface. You would need an 'ssh' configuration command that ended in 'outside' in order to ssh from outside.
Putty is able to ssh without difficulty, so your reference to 'telnet' might just have been a terminology mistake.
Really, multiple threads doesn't help.
Sorry, but this is Usenet, and people respond or they don't. Multiple threads tend to annoy people. When you say that a situation is urgent, and that your ISP doesn't want to help, what you are telling us is that your situation calls for a consultant, either a private firm hired, or a support contract or "incident" call with Cisco. Particularily on a weekend, when people have family things, or yards to tend, or festivals to go to, or vacation to, urrr, vacate.
Anyhow, if your smtp has stopped, then double-check your DNS entries for the affected IP address. Ensure that the IP address has a valid reverse address translation -- better yet, a valid reverse address translation in the same domain as people are sending the email to.
Oh yeah, another thing: if you won't have access to the device until Monday then the situation must not be quite so urgent. An urgent situation is when you get the company president out of bed to get the doors open for you, and the company president is happy to do so because the president realizes what the technical problem means to the company.
Hi Walter Thank you very much for posting your reply. I don't understand what you mean by NAT. The firewall configuration uses static to map inside and outside IP's. If you have read the configuration that I posted, you'd know that we don't use NAT. Or may be I am an ignoramus. Also, the firewall configuration didn't change over many years and it did work exceptionally well despite the drawbacks you mention. Kindly read the configuration and let me know what's wrong with it.
I would like to start with a minimal configuration and build on it. Can you please suggest what minimum rules are required for the PIX6 to work and at the same time make the mail server available?
You are right. I have allowed all icmp messages to pass through the firewall. The firewall, however, is blocking SMTP. Somewhere I have read that the following line is more robust
no fixup protocol smtp 25
As it will allow ESMTP commands as well.
Thank you sir for the suggestion. I want to get this email thing right in my heads. There is no point in aspiring for better things when I am stuck at a very basic level. I hope I am being clear and communicative. I want the PIX 6 configuration to work before I go and make an upgrade. Further more, this configuration has worked for 5 years without a hitch in the email delivery.
Thanks for the clarification. How do I make any host from outside to connect to PIX?
Will "ssh any 255.255.255.255 outside" work?
The email issue is back logged for more than 4 days now. So I was very desperate to get it fixed. I don't know what a consultant can do or how to advertise for a consultant. Our company is a startup and has a very tight budget. We do all the development in house. We have a windows maintenance contract with Primary Support. I called them and they were not helpful. They wanted to telnet/ssh to the firewall and that was not possible now. Please note that my intention is not to abuse the usenet. I want to learn as I go through your response. You have been very kind in the past and as always in explaining things. So my kind regards to you.
With respect, you shouldn't be let anywhere near a production firewall if that is the case.
You have been told that the pix code rev you are running has serious issues and your response of
Shows that you're failing to comprehend the message.
At your present level of technical expertise you are incapable of fixing the problem. Time to pay someone who does or find an alternative solution until you do.
greg
NAT is Network Address Translation, and NAT applies to nearly all traffic between different interfaces on a PIX. It is most obvious when a host has a different inside address and outside address, but as far as the PIX 6.1 is concerned, it also applies to five of the six different ways to have an IP address be the same on the inside and the outside... and you don't happen to be using that sixth way.
Bugs do not always manifest immediately.
ssh 0.0.0.0 0.0.0.0 outside
A consultant could go on site and debug the problem more thoroughly -- and be available in case of further problems.
That could be a problem. Consultants can be a bit expensive, especially for a short contract. But not getting in someone to fix your problem can be even more expensive.
Yes and no. Clients that want to speak ESMTP are required by the RFC's to -try- an EHLO packet, and if that doesn't work then to revert to HELO, and servers are not supposed to drop connections upon merely seeing an initial error (e.g., a packet not understood.) But PIX with the smtp fixup did get that wrong for several releases, dropping the connection immediately.
It is possible that the smtp fixup is interfering, but if that were the case then you would be able to telnet from the outside to the smtp port and get -some- answer, from the PIX itself: even in the releases that made the mistake of dropping the session too early, you would get the SMTP prompt from the PIX. However, when I test, I don't get an answer.
Unfortunately my workplace temporarily has some icmp turned off while a DoS attack calms down, and my residential firewall cannot cope with traceroute, so I cannot easily figure out where the block exists. It could be at your ISP even.
How is this different from paying Cisco for tech support? Sharing company secrets with an unknown consultant could backfire. Besides, as I had already mentioned, we retain Primary Support as our consultants. They couldn't figure out where the problem lies.
I worked as a consultant. It is hard to fill extremely short jobs. Besides, these days consultants land into the USA on airlines and are quite pricy. This is not a consultant's job. But I could be wrong.
There are several different levels of technical support contract with Cisco. Unfortunately unless you are big company spending a lot of money, then you don't usually get the full attention of even one person at Cisco. Even a regular "onsite premium service"
24 x 7 x 4 contract usually only gets someone onsite long enough to determine whether the problem is software or hardware... and once a determination is made that the problem is software, you go into the software engineer queue. And if the problem turns out to be complex, involving multiple pieces of equipment, then Cisco will just hand off the problem, saying roughly "get that other part fixed and then we'll talk" (even if it would make the most sense to fix the cisco side.)
And what do you know about your building cleaners? If you do have reason to trust them, then how did you develop that trust?
Sorry, I did not (and do not) recognize "Primary Support". You used the name in the phrase "Windows Primary Support", so I assumed it was either a Microsoft support contract (whom I wouldn't expect to know -anything- about firewalls other than Windows XP built in firewall) or else a company that specializes in Windows (and so wouldn't be expected to know much about firewalls.)
You indicated that the ISP set up the firewall (and now doesn't want anything to do with it); the fact that you did not earlier turn the support over to Primary Support suggests to me that whatever else they do, Primary Support does not have any PIX specialists on staff.
Yes, but there are good people out there.
I'm not sure what you mean by that. It's true that if -I- were to take on the job, I'd have to fly in from outside the USA (a 2 day bus ride would be just too much fun for me to survive), but I'm one of those rare Canucks that hang out here (Merv is another but he's a lot closer.)
If you need someone who *really* understands Cisco equipment, is -very- trusted, and is close by, talk to Networking Unlimited, Tenafly, NJ. I wouldn't want to even estimate their pricing; I get the impression that their pricing structure is somewhat flexible. If nothing else, they can probably refer you to someone local.
I don't mean to sound rude, but you appear to be over your head on this problem. I scanned your configuration, and without having studied it line by line, I would say that the only obvious problem with the configuration is the old PIX softwar release. That means you have a non-trivial network problem to debug, and you don't know how to debug it. So who, then?
I have some ideas on what's wrong, but describing them to you and remotely guiding you through the testing would take a few hours. There are probably other people with the necessary skills also following the thread to some extrent; I suspect strongly that they too are thinking, "This could probably be debugged, but it would take several hours of work." Not that many people with the necessary skills have that much time to -volunteer-, especially on short notice.
(To disambiguate a point: I am not in the consultancy business, and I seldom accept "side jobs", especially ones in the USA, as I do not have an appropriate business structure or insurance set up.)
