IPSec Monitoring for ASA_Series over SNMP
Feb 01, 2006 2 Replies
Hi, we would like to monitor different Lan2Lan connections. We want to see the traffic on a per peer basis and we want to see if the tunnel is up and running. Does anybody know an easy way to do so????
Thanks
have you tried a mib-walk?
If the device is SNMP enabled, do a mib-walk to find the ifIndex of the interface (tunnel) you want to monitor. Once you know it, perform a snmpget on the ifOperStatus. (1.3.6.1.2.1.2.2.1.8.X) Here's a table of the result codes: 1 = up 2 = down 3 = testing 4 = unknown 5 = dormant
here's a sample of how to do this BY HAND:
FIND the if Index (First Step) Unix>snmpwalk -v 1 -c public 10.1.2.3 interfaces.ifTable.ifEntry.ifDescr interfaces.ifTable.ifEntry.ifDescr.1 = STRING: "GigabitEthernet0/0" interfaces.ifTable.ifEntry.ifDescr.2 = STRING: "Tunnel" interfaces.ifTable.ifEntry.ifDescr.3 = STRING: "Null0" interfaces.ifTable.ifEntry.ifDescr.4 = STRING: "Loopback0"
Notice the ".2" after "ifDescr" on the Tunnel interface. THAT is your ifIndex.
Poll that interface for it's status. Unix> snmpget -c public 10.1.2.3 ifOperStatus.2 interfaces.ifTable.ifEntry.ifOperStatus.2 : INTEGER: up
You should also be able to graph the amount of data being transmitted/received by periodically polling ifInOctets.2 and ifOutOctets.2.
There are several good programs out there to help you get this information. - Some are free - Like MRTG.
J.Cottingim
have a loot at
This is exactly what you need
Erik
