Internal Web Server with cisco 1841 problem
Aug 26, 2006 4 Replies
Jump to replies (4)
Hello,
I am new to Cisco and am having mild difficulties. I have a internal ip (192.168.1.x) and an external network (172.16.32.x).
I have a web server in the 192.168.1.x network that is up and running. I setup nat so that the computers in 172.16.32.x can access the web server. That works fine. The problem I am having is that no one on the internal network (192.168.1.x) can access the webserver from the external IP address (172.16.32.10).
ASCII Diagram
[HTTP SERV 192.168.1.100] ------| [FE1 192.168.1.1] [FE0 172.16.32.10] | ------ [172.16.32.x]
So if a computer say 192.168.1.15 points a web browser to 172.16.32.10 they get nothing. They can ping it, but that is all.
Any help would be wonderful!
Thanks Robert
If you're having hosts in the same subnet as the web server (192.168.1.x) access the web server on its external address (172.16.32.10) you need to be natting the source address of the clients so the web server replies to that address and doesn't reply directly back to the clients. Clients expect traffic to come from "172.16.32.10".
BernieM
Here is what I have in my NAT:
Vlan1 inside = 192.168.1.1
FE0 outside = 172.16.32.10
ip nat inside source list 1 interface FastEthernet0 Overload ip nat inside source static tcp 192.168.1.100 80 interface fastethernet0 80
What else would I need ?
Thanks aga> > Hello,
I don't think you can do it because you can't configure an interface as both 'nat inside' and 'nat outside' it has to be one or the other. Clients in the same subnet at the server need to use the servers real adddress.
BernieM
But keep thinking, as you could do it using another device doing the natting. Like a Radware ASD ...
