interface Vlan2 ?
Apr 14, 2006 1 Replies
Doug McIntyre
Cisco must have changed how they created VLANs yet again :) Its either there, or in the vlan database I would guess on these layer-2 switches. You won't be able to bring up the VLAN on a layer-2 switch if you assign it an IP address, only one VLAN can have an IP, and that will…
I have a lot of interfaces on my c2960 configured as VLAN ports?s. Sample: interface FastEthernet0/5 switchport access vlan 2 switchport mode access
Later in my configuration file I have: interface Vlan1 ip address 192.168.1.50 255.255.255.0 no ip route-cache ! interface Vlan2 no ip address no ip route-cache ! interface Vlan3 no ip address no ip route-cache
But what does the statements do? Are they necessary to have? What will happen if I assign all my VLAN?s with a IP address, will I still be able to use the VLAN as normal, and can the IP be used to anything?
regards Martin
You won't be able to bring up the VLAN on a layer-2 switch if you assign it an IP address, only one VLAN can have an IP, and that will be your management VLAN.
