How to retrieve temperature value from Cisco 3270 wireless router.
Jun 12, 2007 0 Replies
Cisco 3270 wireless has an onboard temperature sensor that alerts administrator if router board falls outside the temperature range of
-40 to +203=B0F (-40 to 95=B0C). CISCO-ENVMON-MIB has been enabled on this wireless router, however, I can only retrieve the following snmp data points via snmpwalk:
snmpwalk -v 2c -c public 192.168.0.176 1.3.6.1.4.1.9.9.13 SNMPv2-SMI::enterprises.9.9.13.1.1.0 =3D INTEGER: 6 SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.1 =3D STRING: "Chassis" SNMPv2-SMI::enterprises.9.9.13.1.3.1.6.1 =3D INTEGER: 1 SNMPv2-SMI::enterprises.9.9.13.2.1.0 =3D INTEGER: 1 SNMPv2-SMI::enterprises.9.9.13.2.2.0 =3D INTEGER: 1 SNMPv2-SMI::enterprises.9.9.13.2.3.0 =3D INTEGER: 1 SNMPv2-SMI:: enterprises.9.9.13.2.4.0 =3D INTEGER: 1 SNMPv2-SMI::enterprises.9.9.13.2.5.0 =3D INTEGER: 1 SNMPv2-SMI::enterprises.9.9.13.2.6.0 =3D INTEGER: 1
There is no data point to give the actual value of the chassis temperature.
It would be highly appreciated for you to let me know:
(1)Is it possible to get the actual value of the chassis temperature? (2)If possible, how can I retrieve the actual value of the chassis temperature?
Thank you very much.
