How to move a port from one vlan to another?
Jun 23, 2006 2 Replies
Most relevant reply
Doug McIntyre
The 2900XL is a switch, not a router. It can't do anything on layer-3. set vlan port# is a CatOS command. The 2924xl is an IOS device, you need to use IOS commands. int Faste 0/1 switchport access vlan 2
I have a Cisco 2900 XL router that has 2 VLAN's. I ran "show vlan brief" and it has listed ports . I used set vlan [vlan#] [port#] but it didn't work. The router think vlan keyword is a problem. Can anyone tell me what is the correct way to move ports from one vlan to another?
Thanks for your help
Many thanks for your help
This is how I did it
Switch>enable Switch#configure terminal Switch(config)#interface Fa0/10 Switch(config-if)#switchport access vlan 3
Thanks again.
