How to delete a ip nat inside?
Jul 15, 2006 1 Replies
Most relevant reply
BernieM
I have a problem to delete a ip nat inside line, the command no ip nat inside... doesn´t work. How could I delete this line? Thanks Regards What do you mean it doesn't work? Do you get an error saying it's in use? I think you need to clear any active translations first: "clear…
I have a problem to delete a ip nat inside line, the command no ip nat inside... doesn=B4t work. How could I delete this line? Thanks
Regards
Regards
"clear ip nat translation *" or something like that.
BernieM
