how to configure pvst on a catalyst 3500?
May 19, 2005 2 Replies
Jonathan
in global config: spanning-tree vlan [vlans] root primary | secondary spanning-tree vlan [vlans] priority [priority] This way you create a separate instance of spanning tree, per VLAN, and specify which switch is the root and its priority for each VLAN. Hence, Per-VLAN Spanning…
hello people,
well, basically the question is in the subject. i'm really confused about all the options for this subject, lime mstp, pvst, pvst+ etc.
could someone give me some basic pointers on what's hot and what's not when it comes to this? i can't use the catos-syntax so an example using the ios would be greatly appreciated.
thanks in advance,
sven
in global config:
Hence, Per-VLAN Spanning Tree.
Jonathan
pvst+ is enabled by default.
Don't let the marketing confuse you. It is just basic spanning tree, a seperate one for each VLAN, with a couple of little optional twiddles that may or may not help in your case.
You should choose a root switch and a backup root switch at the centre of your network by setting the bridge priority. You need to do this for each VLAN.
The Cisco BSCMSN book (I have the second edition) has a good chapter on this.
I don't like using the macros much. i.e. "spanning-tree vlan [vlans] root primary | secondary"
It is so easy to just set it the way you want it with "spanning-tree vlan [vlans] priority [priority]"
At least read the configuration guide for your software version.
Unless yor network has specific requirements, in which case you should get someone to help, you do not need to do much.
