How good is Cisco 781
Nov 13, 2006 1 Replies
www.BradReese.Com
You may wish to investigate the Cisco Router Port Matrix: Small Business Network Designer: http://64.224.10.185/sbnd/child/1.0/'s Design a Custom Solution for your Business: Solution Finder for Modular Routers: Brad Reese
We are in the process of setting up a small back office operation mainly in the email support vertical. Would like to know which router will be best for the setup.
Process Type : Email answering through a java based web application. No. of PCs: 3 (P4 2.6 Ghz, 1 GB DDR Ram, 80 GB HDD) Broadband : Wireless RF 5.725 - 5.825 Ghz 64kbps dedicated lease line. Router suggested by ISP : Cisco 871 Future Plans : After 6 mnths - Additional Voice support through soft phone. (2 more PCs)
Your take on the setup mentioned above as well as any other router which would fit the objective besides the already suggested cisco 871.
Would any idea how reliable is the RF (fixed wireless) when it come to weather or packet loss especially when we move to voice support.
thanks n cheers!
Cisco Small Business Network Designer:
http://64.224.10.185/sbnd/child/1.0/index.asp Cisco's Design a Custom Solution for your Business:
Cisco Solution Finder for Modular Routers:
Sincerely,
Brad Reese
