How do I filter VPN traffic?
Apr 26, 2006 4 Replies
Most relevant reply
AM
I can tell how a PIX525 with 6.3(4) should work for the ASA too, as that behavior is the same between PIX 7.0.x and 6.3(4), and ASA and PIX for the most aspects share most of the rules set. Check whether the "sysopt connection permit-ipsec" is disabled. Type "no sysopt…
Hi
We have an ASA5510 where I need to limit access through a VPN tunnel to accept only FTP traffic.
How do I do that?
If I choose to do it in the VPN access-lists, I got a warning.
A person told me to accept all traffic through the VPN tunnel, and then make a separate access-list where I accept only FTP traffic.
But how do I do that?
Shall I assign that access-list to outside interface or to inside interface?
Please show me an example.
Thanks
Brian P.
I can tell how a PIX525 with 6.3(4) works.It should work for the ASA too, as that behavior is the same between PIX 7.0.x and 6.3(4), and ASA and PIX for the most aspects share most of the rules set.
Check whether the "sysopt connection permit-ipsec" is disabled. Type "no sysopt connection permit-ipsec". If that option is enabled the traffic coming from the IPsec tunnels is not matched against the ACL on the interface where the tunnels terminate and so all the traffic encrypted passes through the interface unchecked. Then if the VPNs terminate on outside interface, treats the traffic coming from the VPNs as it came unprotected from the outside interface. Obviously you must merge the new rules with those already present in the access list applied to the outside interface
HTH.
Alex.
Hi
How do I do that?
Thanks
Brian P.
group-policy VPN-Policy attributes vpn-filter value vpn_access_list
Then create an acl named "vpn_access_list" in the case of this example. This doesn't work for webvpn connection as far as I know, but for standard IPSec tunnels it should work.
Of course. VPN "access-lists" are protocol identifiers, but not filters.
Correct.
access-group ...
Assigne the list to the approbriate interface.
Thanks for all your help .... now I can filter properly :-)
B.R.
Brian P.
