Help on VLAN configuration: Catalyst 3750
Oct 18, 2005 4 Replies
Jump to replies (4)
I am going to implement a Cisco LAN. These are the specifications:
Main Server Room: Two Catalyst 3750G24T, two Catalyst 3750 48PS/PoE, and servers
Second IT Room: two Catalyst 3750 48PS/PoE
Aironet 1100 Access point (2 in each floor, 16 in total)
Requirement: WLAN users should only have Internet access. Server access (DB and File Server) should not be available to WLAN users. LAN users should have both internet access and access to the server.
I know I need to use two VLANs. How can I configure VLANs across multiple switches? Is it possible to restrict server access through VLAN and at the same time offer Internet access to WLAN users? Any configuration suggestions, case studies on similar requirement are highly appreciated.
Many thanks in advance.
  1. VLANS across multiple switches is implemented using trunking - suggest 802.1Q trunking be implemented.
  1. Use policy-based routing to ensure the WLAN users only have Internet access.
In addition to MERV's post, you'll need to create the VLAN's on all your switches, or use VTP. If you use VTP, make sure you use a dedicated domain for this series of switches. You don't want an accident where a VTP broadcast occurs across some trunked linked and the next think you know you're loosing VLAN's. It happened to me when I braught up a trunked SNLAN connection and had 2 sites set as servers and 1 told the other to drop 20 VLAN's. It was a stupid beginner mistake, but it happens. It's one of the reasons many people don't like to use VTP.
Thanks for your help.
1) The switch uses Stackwise technology, should I still uss trunking in that case?
2) Any detailed suggestions on policy-based routing? where should it be implemented? And configuration example would be highly appreciated.
Thanks again.
If you have 3750 switches in same rack, use stack. But if the distance between the switches is longer, use something else.
ip address 10.10.10.1 255.255.255.0 ! interface Vlan2 ip address 20.20.20.1 255.255.255.0 ip policy route-map pbr ! interface Vlan3 ip address 30.30.30.1 255.255.255.0 ! ip route 0.0.0.0 0.0.0.0 10.10.10.2 ip classless ip http server ! ! access-list 10 permit 20.20.20.0 0.0.0.255 route-map pbr permit 10 match ip address 10 set ip next-hop 30.30.30.2 ! . ! end
