Exceeding Engineering Limits - What Happens?
Sep 25, 2006 1 Replies
www.BradReese.Com
Hi Daniel, You may wish to personally contact the Cisco Technology Developer Program Help Desk: hope this points you in the right direction. Brad Reese - Cisco Repair Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International…
Exceeding Engineering Limits - What Happens? open original image
Hi, I am trying to put together some documentation explaining what happens when some engineering limits are exceeded for the following metrics. Although I am familiar with a number of these metrics, there are many I am not.
If anyone could assist or point me in the right direction it would be appreciated. Even if you can only offer input to one metric. I would assume that some of these metrics may have hard limits and can not be exceeded, unfortunately I am not in a position to test.
CPU Utilisation Eg. Sustained very high CPU can impact performance & control & data plane processes.
Memory Utilisation Eg. High memory utilisation can impact performance & control & data plane processes.
Throughput (PPS) Eg. Packet loss, which can lead to re-transmissions and additional traffic.
Backplane utilization Eg. Packet loss, which can lead to re-transmissions and additional traffic.
Number of contexts/sec
Slot B/W
Switching capacity
Number of Logical Ports
Number of Etherchannels
MPLS Labels
BGP Peers/Routes
OSPF Adj/Routes
OSPF Interfaces
IGP Peers
RIP Adj/Routes
Static Routes
Routing Table Entries
MPLS TE Headends
Multicast PIM Neighbours
Multicast Routes
Number of VRFs
Number of Routes per VRF
Number of VLANs / SubIFs
Number of MAC Addresses
Max. Class Maps per Policy Map
Max. Policy Maps per Device
Number of Egress Policers
Number of Ingress policers
Utilisation (Redundant Infrastructure links)
Utilisation (Non-redundant Infrastructure links)
Etherchannel Utilisation
Etherchannel Member Link Utilisation
Discards
Error
RPL Lines
RPL Policies
POS Channel Utilisation
POS Channel Member Link Utilisation
BGP unique prefixes
Sessions
ATM PVC Traffic (aggregated)
Forwarding Entries
Hi Daniel,
Daniel, hope this points you in the right direction.
