EAP-GTC and OTP with Cisco 1200 APs
Mar 30, 2005 0 Replies
Hi all,
I am currently trying to deploy a WiFi environment using EAP-GTC authentication with One Time Password (OTP) usb keys on an ActivPack (AAA Server) platform.
The problem I'm facing is while the user roams between access points. It seems that he has to re-enter his password each time he switches to another access point. Is there a way to enable a smoother roaming between the Access Points (similar to the Fast Secure Roaming from Cisco which I believe works only in a native Cisco environment)?
Thanks Kailash
