dns lookup problems *I think*
Mar 29, 2008 1 Replies
For some reason, it's taking a long time for my pages to load. I think the problem is that there is something wrong w/ my DNS servers because the lookup takes almost a minute for each page I try to reach. My previous firewall didn't have this problem.
Can anyone see anythign wrong w/ my 5505 ASA config ? ...
: ASA Version 7.2(3) ! hostname wink domain-name home-net enable password A9//BHDQsDKTXgm7 encrypted names name 192.168.1.0 INSIDE ! interface Vlan1 nameif inside security-level 100 ip address 192.168.1.1 255.255.255.0 ! interface Vlan2 nameif outside security-level 0 ip address dhcp setroute ! interface Ethernet0/0 switchport access vlan 2 ! interface Ethernet0/1 ! interface Ethernet0/2 ! interface Ethernet0/3 ! interface Ethernet0/4 ! interface Ethernet0/5 ! interface Ethernet0/6 ! interface Ethernet0/7 ! passwd A9//BHDQsDKTXgm7 encrypted ftp mode passive dns server-group DefaultDNS domain-name home-net pager lines 24 logging asdm informational mtu inside 1500 mtu outside 1500 icmp unreachable rate-limit 1 burst-size 1 asdm image disk0:/asdm-523.bin no asdm history enable arp timeout 14400 nat-control global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00 timeout uauth 0:05:00 absolute http server enable http INSIDE 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart telnet 192.168.1.11 255.255.255.255 inside telnet timeout 5 ssh INSIDE 255.255.255.0 inside ssh timeout 10 console timeout 0 dhcpd dns 68.87.85.98 dhcpd auto_config outside ! dhcpd address 192.168.1.20-192.168.1.40 inside dhcpd enable inside ! ! ! username myname password /lqt3eDQEYVTSruk encrypted privilege 15 prompt hostname context Cryptochecksum:e5278d7a4794e129e06b688db688755c : end
Please post the output of "show version" to find out what maintenance release you are running
Also post output of show interface
