We are having an issue with DHCP and login to a Novell server whereby the clients can't find the tree. There seems to be some sort of timing issue when a computer boots, when the port on the switch becomes active and when the computer receives an IP address from the DHCP server.
We thought that we had established a procedure whereby users could login 30 seconds after seeing Ctrl-Alt-Del. I'm told that some users have experienced problems even after 2 or 3 minutes.
We have found out that if you try to login too soon it is possible for the computer not to have an IP address. If you then login to the local Windows machine (as opposed to Novell) and issue the appropriate dhcp release/renew commands, the IP is established. Then you can connect to Novell. However, this is too difficult for the average user as you might imagine.
Does anyone have any suggestions on how we can eliminate this issue? Is there a way to guarantee that the IP address is established before Ctrl-Alt-Del is displayed? Do you think there is some other issue going on that we are not considering?
Environment:
- Core switches = Cisco 3750 (qty = two)
- Access switches = Dell 5324 (qty = ten)
- Client machines = Windows XP SP2
All of the access switches are connected to both core switches. The DHCP servers are running on the core switches. The DHCP scope is split in half so that there is no conflict with IP addresses. There are 7 VLANs of which 4 are setup for DHCP.
The access ports (as opposed to trunk ports) on the Dell switches are configured with "spanning-tree portfast".
All of the above is known internally as the new network as is running on 10.x networks.
There is also an old (or current) network running on 192.168.x networks. The two networks are linked by a single cable running from one of the older switches (a Dell 5224) to one of the core switches. There is routing between the 10.x and 192.168.x networks, but I'm reasonably sure that no VLAN is passed back/forth. There is a DHCP server running on the old network on a Windows 2003 box, but the scope is only for the 192.168.x networks.
Thanks,
- Joe
