debug frame replay switch
Jun 21, 2005 1 Replies
debug frame replay switch open original image
I use a Cisco 2522 as a frame relay switch. I can ping from router A to router B thru thru the serial interface with encapsulation frame-relay, but I am not sure if those pings really go thru the FR switch or not.
I use the command debug frame-relay packet on the FR switch but there is nothing displayed when I ping from router to router.
Do I use the wrong command ( I hope so, otherwise my router settings are wrong and the packets really not go thru the FR switch ) ?
Thanks for any advice,
DT
Try 'debug frame-relay switching' - don't forget 'term mon' if you are not on the console. Here's a good link;
