Cisco VPN remote control
Apr 24, 2006 1 Replies
I suppose i have a very easy problem here...i will apreciate all your opinions
I am running a cisco vpn client on XP I need to monitor the state of the connection...i.e. if the vpn falls i need to recive a notification on other PC.
(also, i nedd to run dummy process on net not to fall into inactivity timeout...)
Is there anything already done for this? or should I work on it?
Thanks in advance to all!
If I recall correctly, and the feature still is in the newer versions, there are a commandline available. You can use this to check the connection state. Also there is a Registry key, that you can check on for connection state aswell.
More is in the manuals ...
HTH Martin Bilgrav
