Cisco PIX 506e won't boot
Mar 01, 2006 2 Replies
Cisco PIX 506E hangs during boot. This is as far as it gets:
CISCO SYSTEMS PIX FIREWALL Embedded BIOS Version 4.3.207 01/02/02 16:12:22.73 Compiled by morlee
32 MB RAM
PCI Device Table. Bus Dev Func VendID DevID Class Irq
00 00 00 8086 7192 Host Bridge
00 07 00 8086 7110 ISA Bridge
00 07 01 8086 7111 IDE Controller
00 07 02 8086 7112 Serial Bus 9
00 07 03 8086 7113 PCI Bridge
00 0D 00 8086 1209 Ethernet 11
00 0E 00 8086 1209 Ethernet 10
Any suggesstions?
I can get to the "Testing Mode Menu" by pressing ESC before it hangs. All tests pass:
Numeric Coprocessor: Passed. Protected Mode Test: Passed. Low Memory Test: Passed. Extended Memory Test: Passed.
But if I continue the boot process, it hangs at the same place as before.
i've a few 506e with the same problem, try the following
open the pix, in the middle of the mainboard there is a jumper, set it to the other position, and boot it again
please let me know if it solves your problem!
p.s.anybody know's where the switch is???
kind regard
Richard Kraal
