Cisco IOS Routing Syntax
Apr 06, 2006 5 Replies
Jump to replies (5)
Currently, I have a route set up like this on my 2600 running IOS 12.1:
ip route 69.242.89.0 255.255.255.0 69.242.89.254
However, I no longer want the entire Class C going to .254, just a part of it. How can I do that so a range of IPs can be routed? I tried something like this:
ip route 69.242.89.98-69.242.89.110 255.255.255.240 69.242.89.254
But ofcourse the syntax isn't correct. Is there a way to accomplish this?
"PSX" skrev i en meddelelse news: snipped-for-privacy@t31g2000cwb.googlegroups.com...
The syntax should be 69.242.89.96 255.255.255.240 69.242.89.next hop
The .96/28 will include ip-addresses ranging from .96 to .111
Thanks for the info, but I'm afraid that didn't work for me:
2620(config)#ip route 69.242.89.96 255.255.255.240 69.242.89.next hop
^ % Invalid input detected at '^' marker.
This post doesn't accurately show this, but the ^ is pointing to the "n" of next. Maybe it's because I'm running 12.1 and not a later IOS? Without more memory, 12.1 is the latest I can run.
No, it's because you put the word "next hop" in there. You need to replace that with the IP of the device you want to point it to, ie .254
Thanks for the explination, I understand now. I just thought .next hop was some new syntax I had not seen before :)
"PSX" skrev i en meddelelse news: snipped-for-privacy@g10g2000cwb.googlegroups.com...
Sorry, should have been more clear :-)
