Cisco CSS11050 - IIS5.0 - HTTPS site does not work after bouncing the website
Mar 28, 2006 0 Replies
Hello,
We are using Cisco CSS11050 to load balance between two IIS5.0 websites on two different servers.
Everytime we bounce the IIS, we cannot access the website via https (port 443) using the load balanced address. We have no problems accessing websites individually by bypassing load balancer. Port 80 is not a problem.
We found a work around for this issue - we basically suspend the service in Load Balancer for port 443 and make the service active. Once we do that then we can access https site using load balanced address.
Can some one please help us figure out why this is happening? Also how do we go about fixing this problem. We have enabled http keep-alive for both websites. Here is how we have configured the service in the load balancer.
service s_cog_fb2_443 keepalive frequency 30 ip address 10.8.24.139 protocol tcp port 443 keepalive type script ap-kal-echo-443 "10.8.24.139" active
Many thanks in advance.
Regards
Sekhar
