Cisco Aironet 100 serie
Mar 09, 2006 1 Replies
Hello to you all,
I do have a cisco router as mentioned above ( sorry about my English if i don't say it right).I did install it with an old lap top wich did not have the right wirelees card in it. I think that's the reason why i don't get more then 11,0 Mbps at this time. Before I had a linksys router and i had 54 Mbps. I did something wrong but whatevere i try i don't get it working on 54 Mbps. Who can help me (stupid Dutchman) with theis problem? I tried to reset the router but that did'nt work. Contacting Cisco did not work too.
Ton
firstly the Aironet is not routers, but access point (=bridges) The model you say you have, I think should be the 1100 Series. Same model in the 1100 series does not support 802.11g, but only 802.11b What is your exact model number ? (fx AP1130) This will give you the answer.
HTH Martin Bilgrav
