Cisco 871w no wireless....
Mar 08, 2007 1 Replies
I am unable to assciate to the wireless on this router... Do I have a problem with the hardware or my config?
Router>en Router#sho conf Using 1312 out of 131072 bytes ! version 12.4 no service pad service timestamps debug datetime msec service timestamps no service password-encryption ! hostname Router ! boot-start-marker boot-end-marker ! ! no aaa new-model ! resource policy ! ip cef ! ! ! ! crypto pki trustpoint TP-self- signed-1710299380 enrollment selfsigned subject-name cn=IOS-Self-Signed- Certificate-1710299380 revocation-check none rsakeypair TP-self- signed-1710299380 ! ! crypto pki certificate chain TP-self- signed-1710299380 certificate self-signed 01 nvram:IOS-Self- Sig#3005.cer ! ! ! bridge irb ! ! ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface FastEthernet4 no ip address shutdown duplex auto speed auto ! interface Dot11Radio0 no ip address ! ssid Metro ! speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0
54.0 station-role root bridge-group 1 bridge-group 1 subscriber-loop- control bridge-group 1 spanning-disabled bridge-group 1 block-unknown- source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Vlan1 ip address 192.168.1.2 255.255.255.0 ! ! ip http server ip http secure-server ! ! ! ! control-plane ! ! line con 0 no modem enable line aux 0 line vty 0 4 login ! scheduler max-task-time 5000 end
Thanks, Dan
I would say your config
You shuld use BVI instead of VLAN1
fx this is from a Cisco 1100 AP:
interface FastEthernet0 no ip address no ip route-cache duplex auto speed auto bridge-group 1 no bridge-group 1 source-learning bridge-group 1 spanning-disabled hold-queue 80 in ! interface BVI1 ip address dhcp client-id FastEthernet0 no ip route-cache
