Cisco 2511 cpu usage
Oct 05, 2006 1 Replies
Cisco 2511 cpu usage open original image
Hi there, I have 2 modems for dialing in connected to a 2511 router with some rj45 to 25 pins serial connectors. Somehow router shows 100% usage and when modems turned off is almost 0%. How can I find out what is using the routers cpu? It could only be modem DIP switches or rj45 to serial connectors since routers worked OK before we moved to a new location and we might have changed just the phone cable going into the modem and connectors. Router configuration has not changed, neither has the os(12.1 2b). Thanks, Calin
Hi Calin,
You may wish to investigate Troubleshooting High CPU Utilization on Cisco Routers:
Hope this helps.
Brad Reese BradReese.Com - Cisco eBay Repair Service
