Cisco 1812
Jul 21, 2006 5 Replies
Jump to replies (5)
Cisco 1812 open original image
Hi, i would like to know if someone has never used this router. I read that this model is able to work with WAN failover on the two FastEthernet , in which way it do this? Is it possible use this router to implement this schema?
INTERNET-------WAN1----| | |------DMZ ( 10.10.0.x) ----WAN2---|-------LAN (172.18.1.x)
Thanks, Stefano
Hi Stefano,
High-Speed Failover Diagram:
You may wish to investigate Cisco 1800 Configuration Guides:
Sincerely,
Brad Reese BradReese.Com - Connect Non-VoIP End Devices To Cisco CallManager
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Technical Forums
Cisco 1800 Configuring Dial Backup could be helpful:
Brad Reese BradReese.Com Cisco Jobs
Hi, Thanks all for your answers. If I understand right the failover works only on a physical down not on the logical down , is it correct ? Thanks, Stefano
fantastic, just the documentation I need
