change FTP port
Apr 27, 2007 1 Replies
How do I change my FTP port from 21 to 8888?
On the local network the FTP-server works fine with port 8888. But it can not be accessed from the internet. The FTP client logs on, byt cannot list the files. Gets the error: Transfer channel can't be opened
I think I need to redirect some extra port since I am not using port 21.
What is wrong?
There is my conf om my ASA5500
ASA Version 7.2(2) ! terminal width 120 hostname ASA-xx domain-name xx.local enable password CfJGq9/fxxnP.UdE encrypted names ! interface Vlan2 nameif outside security-level 0 ip address 212.xx.xx.10 255.255.255.240 ! interface Vlan7 nameif inside security-level 100 ip address 192.168.1.1 255.255.255.0 ! interface Ethernet0/0 switchport access vlan 2 ! interface Ethernet0/1 switchport access vlan 2 ! interface Ethernet0/2 switchport access vlan 7 ! interface Ethernet0/3 switchport access vlan 7 ! interface Ethernet0/4 switchport access vlan 7 ! interface Ethernet0/5 switchport access vlan 7 ! interface Ethernet0/6 switchport access vlan 7 ! interface Ethernet0/7 switchport access vlan 7 ! passwd XojxZFfxx2wxqfff encrypted ftp mode passive clock timezone CEST 1 clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00 dns server-group DefaultDNS domain-name DAE.local access-list allow_inbound remark **** access-list allow_inbound extended permit tcp any interface outside eq ftp access-list allow_inbound extended permit tcp any interface outside eq 8888 access-list allow_inbound extended permit tcp any interface outside range 2048 3000 pager lines 24 logging asdm informational mtu outside 1500 mtu inside 1500 icmp unreachable rate-limit 1 burst-size 1 asdm image disk0:/asdm-522.bin no asdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 static (inside,outside) tcp interface ftp 192.168.1.2 ftp netmask
255.255.255.255 static (inside,outside) tcp interface 8888 192.168.1.2 8888 netmask
255.255.255.255 static (inside,outside) tcp interface ftp-data 192.168.1.2 ftp-data netmask 255.255.255.255 access-group allow_inbound in interface outside route outside 0.0.0.0 0.0.0.0 212.242.92.1 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat
0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect
0:02:00 timeout uauth 0:05:00 absolute http server enable http 87.48.39.154 255.255.255.255 outside http 213.150.42.2 255.255.255.255 outside http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart telnet timeout 60 ssh 2xx.1x0.x2.2 255.255.255.255 outside ssh 87.x8.x9.xx4 255.255.255.255 outside ssh 192.168.1.0 255.255.255.0 inside ssh timeout 60 console timeout 60
! class-map inspection_default match default-inspection-traffic ! ! policy-map type inspect dns preset_dns_map parameters message-length maximum 512 policy-map global_policy class inspection_default inspect dns preset_dns_map inspect ftp inspect h323 h225 inspect h323 ras inspect rsh inspect rtsp inspect esmtp inspect sqlnet inspect skinny inspect sunrpc inspect xdmcp inspect sip inspect netbios inspect tftp ! service-policy global_policy global prompt hostname context
Best Regards Martin
I'd rather think that this is because the ftp state machine doesn't know your port 8888. ftp is one of the most difficult protocols for a Firewall since there are two connections in a special context.
Opening port 21 implies some things for port 20 and you'd ave to do the same thing for port 8888 and maybe a second port. But I don't een know if this is possible on an ASA?
Regards
fw
